ok, i have an 89 iroc z with an L98 that has the 2.77 rear end. i was told that the 3.73 ring and pinion for a chevy 10 bolt would fit my rear end. then i was told that i would have to buy a ring a pinion for a borg warner rear end. do i have a b.w. rear? all i know is it is a stock 2.77 rear end that came with the L98 and i want to get steeper gears. what gears do i need to get. thanks
89 iroc L98
new engine, less than 4k miles
!smog pump
!tb coolant
gutted airbox / ram air ducting
ported plenum
1 5/8 shorty headers
true duals 2 1/2 pipes
no cats
trans go shift kit
soon to be some 3.73s
89 iroc L98
!smog pump
!tb coolant
ported plenum
no cats
trans go shift kit
With the 2.77 gears, you have the 9-bolt "Aussie" rear, aka: Borg Warner rear. Regular 10-bolt gears will not fit. There are a few companies that do sell gears and rebuild kits for these rears, but they are much more expensive than the much-more-common 10-bolt rears.
Another option is to replace the whole rear with another one from '90-92 with the big rear disc brakes, a posi, and a 3-series carrier/gears. As long as you have the 3-series carrier, you can easily have 3.42's or 3.73's swapped in.
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
What sbout swapping factory 3.73's out of an 84 drum brake rearend into a 88 formula with disc's that has stock 3.23's in it
Yep, I believe you can do that. Just have the gears swapped from one carrier to the other if the '88 has a posi and the '84 doesn't. If the '84 does have a posi, then you can swap over the whole carrier. I think it was in '89 when GM switched to 28-spline axleshafts from 26-spline, so you should be safe here. If the '88 axle does have 28-spline axleshafts, then you can only swap the gears from one carrier to another...
Greg Westphal
'87 IROC 305TPI/A4
Greg Westphal
'87 IROC 305TPI/A4
You can only do that if the 88 has a 10-bolt. It probably has a 9-bolt, in which case the 10-bolt stuff from the 84 won't work, as described above.
