Need info on tranny swap from '91 Caprice to '89 IROC
Old Oct 10, 2000 | 03:10 AM
John'89L98's Avatar
Hey all... I pulled the trans on the '89 a couple of days ago because it was slipping really bad in all gears, and the governor finally started to stick. Anyway, I have a newly rebuilt trans from a '91 305 "Special Service" Caprice (ex-fire chiefs car).
I swapped the case extension w/ the speedo gear, the TV cable, dipstick, and gear select lever piece. The governor is on order from GM, and I'm assuming it's all right to keep the Caprice converter in since it more than likely has a higher stall. I would swap them, but I'm afraid of all the debris that might be hiding in the bad trans' fluid. Am I missing anything? Thanks. - John '89 L98
Old Oct 12, 2000 | 10:32 AM
John'89L98's Avatar
All right, the governor is in, and I'm about to put the trans back in... Am I missing anything? - John '89 L98
Old Oct 13, 2000 | 01:47 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I think that's it... as long as everything electrical hooks back up, you should be OK
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:52 PM
mustangman65_79
Aug 11, 2015 03:17 PM
