someone please tell me how to change the fluid in a t-5
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
ok i went to the parts store and looked at the haynes manual and it doesnt say anything about changing the fluid the t-5. tells you how to check the fluid level. but not how to change it! can anyone tell me how to do this! i need to this to my tranny. the reason why im asking is ive heard people say if you remove the wrong plug, that yeah the fluid will drain out, but you will lose reverse or something like that. please help.
Car: Camaro RS
Engine: obd2 350 lt1
Re: someone please tell me how to change the fluid in a t-5
Im almost positive filler is on the pass. side of the gearbox. There is one toward the top of the side and one on the bottom. They take a 3/8 extension to remove them and the lower one drains the top one is the fill.
also i think you use dexron automatic fluid for some reason and fill till it starts coming out of the hole then its full. I may be wrong
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
92camaroJoe
Aug 13, 2015 06:07 AM
