down shifting manualy/ free wheeling
Old Oct 21, 2000 | 12:35 AM
Greg90iroc's Avatar
When i down shift my tranny manualy now it free wheels and the rpms go to 700 no matter that gear i am in or what speed i am going. What gives if i drop it into 2nd @50 mph the rps do not change. when i hit the throttle the rpms rise like i am free reving untill it his where the should be and then the car just breaks the tires loose. when in drive or on the throttle there is no slipage the tranny acts just as it should what gives? i think some thing broke in there. what was it? can it be reapaired easily? i need some help guys.
90 iroc l98
last season best corected 13.62 @102
mods
full exhaust, AFPR, pulley, jet stage 1 chip, billet servo, 52mm throttle body and a few other little things.
Old Oct 21, 2000 | 12:46 PM
Greg90iroc's Avatar
The problem here guys is no engine breaking in 2nd or 3rd or 1st gear. in over drive it works fine. Does any one know what i broke. is it the forward sprag? Any one know how hard it is going ot be to fix? or about how much it will cost? help please.
90 iroc l98
mods
Old Oct 22, 2000 | 12:56 PM
Greg90iroc's Avatar
ok i have narrowed it down to the over run cluch i belive. There is either some thing in the valve body that is not allowing it to engage or some thing in the servo or posibly the cluch is toast how ever it does not even try to grab so i think the cluch is probly ok that brings it down to some thing is broke in the servo or valve body. any thoughts? am i right or is this alot bigger problem than i think.
90 iroc l98
mods
Old Oct 23, 2000 | 07:21 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
How did you narrow it down to the overrun clutch? Anyway, sounds like you are on the right track. As for it not working, its not the servo, it has nothing to do with it. In the valvebody? Possible, but not really likely. You may have burnt the clutches up, there is only two. It is possible that you did break the overrun clutch hub wich attaches to the foward sprag. I would pull it out and tear it down. Its no big deal to replace.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Frozer!!!
Jan 19, 2024 04:55 PM
backtothe80s
Sep 5, 2015 12:39 AM
Thornburg
Aug 25, 2015 01:46 AM
overdriv
Aug 20, 2015 03:52 PM
kah992
Aug 19, 2015 02:55 PM
