What kind of rear do i have in my 91 R/S??
Old Oct 23, 2000 | 08:33 PM
'91 Camaro R/S 305 TBI's Avatar
If i have a limited slip Diff. is it the same as a 87 Vette with limited slip. Wanting to put 3:07 gears from a Vette into my rear end wich has 2:73 gears. Would it work? If not what should i do?
Old Oct 24, 2000 | 01:52 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, the Corvettes use a different rear end with the independant rear suspension. You have a 10-bolt rear end, more than likely not posi, with 2-series 2.73 gears. The easiest swap would be to a set of 10-bolt 2-series 3.08 gears. Next would be an SLP posi with 3.23 or higher gears.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
novaderrik
Aug 10, 2015 12:44 PM
