Transmission Linkage WOWS
Old Aug 1, 2008 | 09:29 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Replaced the shift cable on my 700r4 a couple months ago. Today i drove my camaro around all day. I got in it tonite and went to back up and i couldnt select any gears, the car just goes forward. I tryed putting the tranny in park from under neath and then hooking the cable up to the gear shifter when its in park but the cable isnt long enough. Any suggestions? Why would this happen?
Old Aug 1, 2008 | 10:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Transmission Linkage WOWS
Check that the cable is properly installed in the bracket on the transmission and on the shifter. It's a little easier if the transmission and shifter are both in neutral instead of park.
Old Aug 1, 2008 | 10:08 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
The cable seems to be in the bracket correctly. It doesnt seem like the cable is damaged either.
Old Aug 1, 2008 | 10:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Did you check both ends? You didn't have it in 1st by mistake?
Old Aug 1, 2008 | 10:46 PM
Ben92's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
nope i have gear control what so ever. sum how its fooling the neutral safety switch, i start it and it jumps forward and wants to take off.
Old Aug 2, 2008 | 12:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The neutral safety switch is on the shifter, it doesn't know what position the transmission is in.
If it's jumping forward, then you don't have it in park.
budowski
Carburetors
Oct 2, 2015 10:16 AM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
IROCNParts
Sep 24, 2015 10:50 AM
jtwoods4
Sep 3, 2015 05:39 PM
