Pinion seal????
Old Nov 8, 2000 | 07:40 PM
89 GTA L98's Avatar
Pinion seal????
My pinion seals leaking....is this an easy job? Take off driveshaft....pinion..and replace seal???
Old Nov 8, 2000 | 09:30 PM
Superman's Avatar
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
Yep,easy fix.
Old Nov 9, 2000 | 09:19 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Wait, isn't that a crush seal (copper)? I believe that involves re-setting all the adjustments on the gears (backlash & etc)?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 9, 2000 | 10:11 AM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
It's an easy fix you do not have to reset back lash or anything else.
Old Nov 9, 2000 | 11:53 AM
badbird88's Avatar
You do have to replace the crush sleeve and make sure you torque it to exact specs. It is a lot of torque to get the pinion nut tightened back down and then you have to use a small torque wrench to test the turning resistance (in-lb torque wrench) but this can't be done with everything on the axles (rims, brakes, ect). Just make sure you get the pinion nut tightened down properly and replace the crush sleeve with a new one DO NOT re-use the old one. You might be able to pick up some good info in the Chilton or Haynes manual about these steps. Also make sure you don't scratch the yoke surface when you take it out or put it in. Wrap it in a old towel or something to prevent it from getting scratched or nicked...if it does this will also cause leaks if its where the seal mates to the yoke.
1988 TA 300+hp 350 w/ TBI and Holley TB unit, Holley projection intake,
WC T-5, 3.42 gears w/ Auburn posi. MSD 6A, edelbrock TES headers, dynomax 3" cat and cat-back system, ACCEL coil, polyurethane bushings all around, aluminum driveshaft, Mr. Gasket open air cleaner.
1993 S-10 w/ 4.3L V6 TBI, slightly bigger cam, Mild polish job and 3 angle valve job on heads, Edlebrock TES headers, Dynomax cat back, MSD 6A, ADS chip
2000 Kawasaki KX 125
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
