4th Gen. rear swap ?
Old Nov 13, 2000 | 10:30 PM
Bad Analogy's Avatar
I have an 89 Formula with a busted disk-brake 9-bolt and was wondering what i would be up against with installing a used rear from a 4th gen. Will the disk brake systems be compatable? I'd like to use the 4th gen. rims on the rear also. Would the wheel spacing work? Would it look "right"? Is any fabrication / cutting / welding required? Which particular rear/gear ratio should i look for? I'm looking for someting in the 3.2x-3.4? range.
Any and all help would be appreciated.
-JASON
Old Nov 13, 2000 | 10:50 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It's a direct bolt in but the 4th gen diff is 2 inches wider per side.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Old Nov 13, 2000 | 11:31 PM
Could i get rear wheels with backspacing to compensate?
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sreZ28
Aug 14, 2015 07:48 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
