question on rear diff swap
Car: 1992 Camaro RS 25th Anni.
Engine: 5.0l TBI
Transmission: 700R4 Automatic
Axle/Gears: 3.73 Gov lock
I have a 91 RS with a 3:23 drum rear, My buddy has a 87 Chevy silverado 1500 (half ton) with a 10-bolt 5 lug posi 3:73 rear.
I was wondering if it is possible to do a complete swap and if it would be a bolt on job, or am I going to have to fab mounts or anything?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: question on rear diff swap
Won't fit. Third gens use coil spring and torque arm suspension. The pickup truck is a simple leaf spring system. Although all the mounting hardware can be cut off and swapped over, there's no way to attach the torque arm. The pickup truck diff is also wider than a third gen.
Engine: 5.0l TBI
Thanks for the info, looks like the swap is going to be a no-go then.
