where do you have your external trans filter mounted
Car: 1984 z28 camaro / 2019 accord sport
I am thinking under the battery tray would be the best spot but lets see some pics of where you have it.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: where do you have your external trans filter mounted
Why do you need an external transmission filter?
Do you mean a cooler?
mainly because it is allot easier to change, filters out smaller particles, and came with a boss for a trans temp gauge. I also have a auxiliary trans cooler. I don't want to grenade this trans.
Car: 87 IROC L98
The filter inside the tranny pan does a fine job of keeping metal out of the oil. You need to have the internal filter for the pump to suck up oil and anything that gets through that filter, will probably be too small for the external filter. Under extreme use, the internal filter should be replaced a minimum of ever 2 years. Under normal street use, 5 years is fine. An external filter would never get dirty. It's a waste of money.
You won't like a temp sensor in a cooler line. Temp sensors should be in the pan to tell you how much heat is in the oil after it's been used. If in the cooler line then it's either hot from going through the pump or too cold after going through the cooler.
The only way an external filter would be effective if it was installed between the oil pan and the pump which you can't do.
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
maroe624
Apr 16, 2017 08:29 AM
beachrodder
Aug 25, 2015 08:05 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
