Suitable ratio with 6 speed trans?
Old Aug 20, 2008 | 01:40 PM
Hotrodder's Avatar
Car: 1934 Ford Roadster
Engine: 350 CSB
Hi!
I have a T56, 6 speed trans on my car and the rear axle ratio is 3,54:1. Wouldn't it be better with something around 4,00:1?
5th gear is 0,75 overdrive and 6th is 0,5 overdrive.
The car isn't on the road yet and I'm wondering how much time I should use to track down another rear axle?
Motor is a near stock CSB.
Old Aug 20, 2008 | 03:28 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Suitable ratio with 6 speed trans?
Most people go with a 4.11 or 4.10 gear with that trans. With that much of an overdrive it shouldn't hurt all that much. There are calculators that will tell you the motor rpm at whatever speed from trans ratio, axle ratio, and tire height.
Old Aug 20, 2008 | 03:57 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
What kind of rear end do you have? Ford 9"? Lots of selection in that...
As mentioned, 4.10/4.11 is common. If you don't intend on cruising at 120+ MPH, you can go even higher (4.56 or more). Depends on tire height too. Looks like you've got tall tires so...
What the heck is a CSB?
Nothing wrong with 3.54, you just won't have the snap off the line.... Or the fun of shifting out of first gear at a blazing 3mph ...
Old Aug 20, 2008 | 04:45 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Chevy Small Block maybe.
Old Aug 21, 2008 | 01:05 AM
Hotrodder's Avatar
Engine: 350 CSB
Hi and thank you for your inputs!
The car is a fenderless 34 Ford roadster. The reason I ask at this board is that you are much more familiar with the T56 transmission than the guys over at the hotrod boards.
And It is a former Roadmaster L05 Chevy Small block (CSB) in the car too. Rebuilt to carb, but still a motor well known to you here at thirdgen.org.
Hope it's ok.
The rear axle is a Jaguar IRS unit by the way.
Old Aug 21, 2008 | 09:45 AM
Sonix's Avatar
Car: 1982 Trans-Am
I've never heard anyone refer to it as a "CSB"... Most places call it a SBC, Small block chevy.
But ok, I gotcha...
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
happyhapka
Aug 15, 2015 04:42 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
