backlash
Old Aug 21, 2008 | 11:48 PM
51F1's Avatar
Car: 1991 GTA,1951 ford f1 pickup
Axle/Gears: 3.42 10-bolt
backlash
how much backlash should you have between the ring and pinion and also how do you shim the carrier.The last time I had the rear apart the carrier had to really thick shims( like a 1/4") one on each side, do I replace them with thinner shims or what?
Thanks for the help
Matt
Old Aug 22, 2008 | 02:52 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: backlash
You're right, the stock shims are cast iron ones, about .250" (+/- .003 in my case..)
If you're replacing the carrier, you can try the stock shims. Check backlash and pattern. If you need to change it, buy a shim kit, and start stacking. Thick shims on the sides, thinnest ones in the middle of the stack. Got a book on this? this is pretty important stuff, and I haven't described this completely here....
Old Aug 23, 2008 | 11:21 PM
SDalt404's Avatar
Car: 1988 GTA
Transmission: 5 Speed
Re: backlash
If I am not mistaken it's .006-.010 is the acceptable range. Have fun shimming that and get a dial indicator with a flexable mount.
Old Aug 24, 2008 | 04:27 PM
51F1's Avatar
Re: backlash
any recommendations for a book to help with the swap. The plan is a complete rebuild of the rear. any help is appreciated
gord327
Oct 3, 2015 01:25 PM
dimented24x7
Sep 17, 2015 06:58 AM
camarokev400
Jun 30, 2005 10:29 AM
25THRSS
Feb 6, 2004 05:27 AM
alloy
Nov 27, 2002 01:33 PM
