Shifting Problems.
Old Aug 22, 2008 | 03:46 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
Axle/Gears: 3.23 posi
Shifting Problems.
OK, need some more help...
Other than the low idle that I need adjusting, the other issue is the shifting. The 700r4 transmission was rebuilt less than 12k miles ago and I never had this problem until the other day.
When I'm getting on the highway, with the shifter in OD, it seems to fail to shift from 3rd to 4th for a few seconds and then finally does so with a jerk. If I down shift from OD at that speed and then shift back up to OD, it doesn't happen. However, while this happens, I lose power (not electrical power) but "power", power.
The ATF is level and fine, tranny is rebuilt, I did have the transmission mount replaced and new cat's put on. All lines/hoses are also connected and tight underneath the hood/chasis.
Any ideas or suggestions?
Old Aug 23, 2008 | 01:34 PM
IROC444's Avatar
Car: 1990 IROC-Z
Engine: TPI 350
Re: Shifting Problems.
bump
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
bjpotter
Oct 4, 2015 07:48 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
