HOW DO I GET THE DAMN EBRAKE CABLE OFF!!
I am in the process right now of doing a drum rear swap and have gotten everything disconnected except the ebrake cable. It says nothing about it in the Haynes manual. The haynes manual also skipped over a few important steps in removing the rear end, such as remove the track bar. I'm really losing faith in the Haynes..........
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
bsa
If you are trying to get the e-brake from the backing plate the best way I have found is to use a deep well socket.Can't remeber what size I used but just slide it over the cable to the retaining bracket to release the tabs you wil just have to experiment with different size sockets
Put a small hose clamp around the sprung out tabs about 1/4" away from the backing plate, tighten the clamp until the tabs are compressed, pull the cable back about 1/4" up against the clamp, while pulling back on the cable release the clamp by unscrewing and the cable should pull right out!
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
