i have a t56 in my z, has been in there for 25000 miles, no problems that i know of, a little noisy when in neutral with my foot off the clutch peddle maybe T.O. bearing? not sure, but has been like that for a while, also makes a bit of a grinding bearing noise if i dont give it enough gas when starting from a stop. so a couple times, my clutch peddle just stayed on the floor, but the clutch did not release, so i was stuck in gear. now today, it did it again, went back to normal, did it again, then back to normal again. to get it off the florr, i have to put my foot behind the peddle and pull it up. i waited 0 min, and now the clutch either sticks down, works normally randomly, but about 80% of the time the clutch engages as soon as i start letting it up off the floor, when before this all started it wouldnt engage untill i almost had my foot completely off of it. also i have 4th gen peddles fyi. so does this sound like the seal on the master cylinder is blown, or the slave? i dont know what the crap is going on! oh, my fluid is full and not bubbly.
sounds like a problem with the master clutch cyl. i would pull it apart and inspect the seals on the piston inside.
bump
definitely sounds like a fluid problem have somone sit in the car and pump the clutch pedal. i bet you will find a leak
