what is the deal with stock axles? need info on durability, etc.
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
how much torque can the stock axles in my '91 RS handle? With all of the mods that I have, I think I will be putting out some substantial torque. Let's say 400 ft.lbs. to be safe - really safe.
I want to beef up my rear end this spring, and I want to be sure I don't have to do it again any time soon.
I plan on getting a new differential (with limited slip), with new gears (3.73s). I have drum rear brakes.
Keep in mind that I have the (stronger) 28-spline axles. I am pretty sure that I should get new axles, but I really don't know too much about what the hell I am looking for.
What do you guys think? What should I look for in axles? Where can I fond them?
Thanks a lot for the info.
-Brian
1991 Camaro RS - Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, SLP 1 3/4" Stainless Headers, Edelbrock Victor Series Water Pump, MSD 6AL, Blaster Coil, 8.5mm Super Conductors, Accel Cap and Rotor, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
Join the Third Generation F-Body TBI Web Ring
z28boy@twcny.rr.com IM name: Z28 Boy
-Brian
Brian's 1991 RS
Car: 82 camaro SC
Axles aren't the weak point. I would get some richmond gears, a powertrax locker, HD diff. cover with the bearing preload, weld the axle tubes to the housing, etc. You will tear the gears apart long before the axle's get hurt.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
9192camaro
16
Feb 3, 2019 12:21 AM
