Need parts to convert to WC T-5
Old Jan 10, 2001 | 01:14 AM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I'm beginning to gather all the parts I'll need to swap my 700R4 out for a T5. My problem is I don't know where to begin. The junkyards in my area have barely any thirdgens, so finding a donor car is nearly impossible here. Is there anyway I can score myself a nice WC T5 on the net? Some kind of junkyard search or something. The other problem is how much should I really expect all the parts to cost. I keep hearing different amounts. Somebody says it costs nearly as much as a T-56, someone else says it can be had for a song. For once I need to know what I should expect so I can start ASAP. I can't afford to wait for my transmission to take a dump before starting on the T5.
Also, did all V8 thirdgens come with the WC T5 or only TPI models?
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
Old Jan 10, 2001 | 11:25 AM
ev305tpi's Avatar
Car: 92 & 91 Z28 1LEs, 87 IROC-Z, 90 ZR1
Engine: L98, LT5
Transmission: 700R4, 6-speed
Axle/Gears: 3.45, 3.42, 3.73, 3.27
I am doing the same swap right now and am in the process of buying everything that i need as well. So far, this is what i have spent on parts:
87 non WC T-5, out of a 305TPI with bellhousing and clutch fork was $100
New clutch pak was $182
hydraulic system was $50 with petal *** 'y
standard shift starter was $62
Hurst billet shifter was $162.95
Console pieces and lower floor boot were $20
I still need to buy a flywheel, panhard bar bracket, and pay for the trans rebuild - hope this helps - Erik
86 IROC showcar
305tpi code 13 Silver on carmine red
Old Jan 10, 2001 | 01:05 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
88-92 T5's are all World Class, regardless of the car it came out of. There is a section in the FAQ here on what you need to swap.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 10, 2001 | 07:23 PM
merf23's Avatar
88IROC - i have a bellhousing with for and slave cyl if you are interested.
EvilTA - i have a flywheel from an 84 L69 if you are still looking. I may have a panhard bracket (have to check)
Sean
(merf23@yahoo.com)
1992 Trans Am
May 10, 2023 07:19 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
