Electric Speedo to Mechanical?
Old Sep 24, 2008 | 06:41 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
My car is set up for a mechanical speedo cable. However, if I buy a transmission that takes an electric speedo cable, what is involved to change it over to mechanical?
Old Sep 24, 2008 | 07:17 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Electric Speedo to Mechanical?
IIRC, simply plug your current set-up into the new trans. A search will provide more info.
JamesC
Old Sep 24, 2008 | 08:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Well, you'd need an electric speedometer in your cluster. Some people take a mechanical style tranny and use an adapter to get an electronic signal for an electronic speedo. I don't think you can go backwards, so I think you'll need an electronic speedometer
Old Sep 24, 2008 | 01:37 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
As James said, the speedo setups in the transmissions are interchangable. Take your cable speedo setup from your old trans and put it into the new trans. However, this only works if the tranny's are the same, both 700R4's or both T5's. You cannot put a T5 speedo into a 700R4 or vice-versa.
Old Sep 24, 2008 | 01:44 PM
Sonix's Avatar
Car: 1982 Trans-Am
ohhhh! I understand now
Old Sep 24, 2008 | 03:20 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Ok, im going from a 700r4 to a T5. Thanks for the help.
Hotrodboba400
Dec 10, 2019 07:07 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
TrevinE
Sep 14, 2015 03:20 PM
webeeZ28
Sep 14, 2015 12:00 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
