Need advice on rear end
Old Sep 25, 2008 | 03:42 PM
92RS702's Avatar
Car: 92RS
Engine: 305= boat anchor
Axle/Gears: 4th gen 3.23
I noticed that my diff was leaking fluid, when I jacked the car to get a better look I could see that it is coming from where the axle tubes join the center section,I've never had this happend until now,so what is the best thing to do,should I just weld the axle tubes or is there something else I should do?
Old Sep 25, 2008 | 04:45 PM
big gear head's Avatar
Re: Need advice on rear end
Most GM rear ends have a small leak in this area. Is it leaking enough to be a problem? If it is then you might have broke the plug welds loose and slightly rotated the tube in the center casting. If this is the case then you probably should get another housing. Welding mild steel axle tubes to the cast iron center takes special welding skills.
Old Sep 25, 2008 | 11:49 PM
92RS702's Avatar
Car: 92RS
Thanks for the response,it does leak quite a bit,if I weld it, will this take care of the problem,and is it even worth doing it?
Old Sep 26, 2008 | 06:50 AM
If you weld it then you need to be sure that the tube is lined up correctly first. If the tube had turned in the housing then it must be set right again. The rear end must be disassembled before you weld it. It might be easier to get another rear end.
Here is some information on welding the tubes.
http://www.nastyz28.com/forum/showth...ing+axle+tubes
Old Sep 28, 2008 | 07:17 PM
92RS702's Avatar
Car: 92RS
Ok,I guess I'll have to start looking for a rear end, thanks again.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
