I need help getting these U-Joints out!!!!!
Old Jan 16, 2001 | 04:07 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
How in the world do you get the U-joints out? I have an aluminum shaft and I don't have that U-shaped tool the book says to use. What can I do?
Old Jan 16, 2001 | 04:38 PM
ede's Avatar
ede
if they're the original u joint gm puts a liguid plastic in and lets it harden for a retainer. you should be a ble to see a little tab of it sticking out a hole in the side of the hole the bearing cap goes through. heat it up with a torch and the plastic stuff will squirt out. after it's all done squirting out it'll be a lot easier to get out.
ICON Motorsports
1st & 3rd
Old Jan 16, 2001 | 04:54 PM
88IROCARMY's Avatar
I don't think the aluminum shafts had the plastic filler, since the alum shaft had Spicer U joints. I guess you have the problem with pusing the U joint to one side and still the yoke cap not coming off due to interference with the shaft. Keep working the U joint back and forth and atempt to grab the cap with some pliers. Hope this is your problem???
Old Jan 17, 2001 | 01:18 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Sort of, I got the snap rings off the end caps. I can't get the caps off though! How is it done? I've tried prying, cutting the washer a bit and still no result. What else can I do?
Old Jan 17, 2001 | 01:56 PM
87RS402's Avatar
Big socket, little socket and a vise = U-joint press
Smack shaft ear lightly while under pressure if nessacary
If above doesn't work warm u-joint end to expand aluminum and try again
Reinstall new ones with light coating of anti-sieze to avoid same problem in the future
[This message has been edited by 87RS402 (edited January 17, 2001).]
MrJ
Jun 5, 2002 11:33 AM
86Chicken
Jun 16, 2001 12:02 PM
