rear disc brake swap
Old Jan 21, 2001 | 01:41 PM
donc's Avatar
I have an 89 Iroc with 9 bolt rear end. Can I switch the rear disc from the 9 bolt and put them on a 10 bolt rear end that has drum brakes? thanks
Old Jan 21, 2001 | 02:36 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
to do disc to drum it is a long process and in my opion not worth it, you have to cut the axle housing ends off and weld the ends from another disc ten bolt on it.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
