v8 T5 behind v6?
Old Oct 1, 2008 | 10:10 AM
jaseman2134's Avatar
Car: 1987 camaro
Engine: 3.1
v8 T5 behind v6?
i posted this in the v6 section and was recommended to repost here..
i just finished putting in a 3.1 and a t5, but the first gear is a 50/50 chance of going in gear and fourth gear has a worn ring i think so it grinds going in.
now, i have a t5 from a v8 and was wondering if changing the input shaft is the only thing necessary to do that swap?
i know the gears are slightly different and that one or two guys on here have done it but i could not find any threads detailing it.
skip shifting is fun and all but i still kind of want to be able to get through all the gears.
Old Oct 1, 2008 | 04:22 PM
923.4v6's Avatar
Car: 92 Camaro RS
Engine: 3.4/3500 hybrid
Transmission: 5-speed
Re: v8 T5 behind v6?
I thought about putting one behind my v6 and done a little research and found out that there is a clutch that is the same size as the v6 but with the same spline as the v8. If you can find out which one it is you wont have to change the input shaft. I'll look for it later.
Old Oct 1, 2008 | 07:17 PM
Car: 1987 camaro
Engine: 3.1
oh wow, didnt even think of that hah, ill look into it too.
Old Oct 1, 2008 | 07:31 PM
923.4v6's Avatar
Car: 92 Camaro RS
I found it just search v8 t-5 in a v-6
Old Oct 1, 2008 | 11:12 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://www.inliners.org/Jack/t5_page.html
http://www.inliners.org/Jack/T5tech.html
gm, t5, v6, v8
