Positrack ID
Old Jan 18, 2001 | 10:14 AM
greearhr's Avatar
Positrack ID
What's the easiest way to tell if I should have a posi rear end? VIN number? Rear end tag have a "P" or something?
Thanks for any info!
Old Jan 18, 2001 | 10:59 AM
89RSProject's Avatar
I could very well be wrong on this, but I have the RPO code of G80 which is the positraction, limited slip. I also believe the RPO #'s should be located in your center consol, mine were. Hope this helps atleast a little bit
Old Jan 19, 2001 | 10:16 AM
a73camaro's Avatar
Do a burn out.
If both wheels spin - posi
If one wheel spins - open, non-posi
Old Jan 20, 2001 | 08:40 AM
ede's Avatar
ede
the burn out test only works if the posi does., rpo only works if it's not been changed. all the posi rears i've ever saw had a metal tag on the cover, that would be something to look for too. i'd go rpo, burn out, and then pull the cover and see.
ICON Motorsports
1st & 3rd
Old Jan 20, 2001 | 11:34 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd skip the other steps for the reasons ede mentioned and go straight to pulling off the cover... if the fluid hasn't been changed lately, it needs it anyway, good excuse to pull the cover.
ICON Motorsports
Old Jan 22, 2001 | 12:34 AM
a73camaro's Avatar
I have never seen a worn out posi so that one could not do a two legged burnout. Has ANYONE seen this?
You can also put the car in neutral, lift up one rear wheel and see if it rotates. If it rotates, non-posi. If it is "locked", posi.
Again I have never seen a worn out posi that failed this test (about 30 rear ends to sway my voting).
Is it possible that a posi carrier act like a peg-legger, yes.
Is it possible to put a Ford engine into a 3 gen Camaro, yes, but you don't see it.
Old Jan 23, 2001 | 12:44 PM
greearhr's Avatar
I recon changing the oil would be a good thing. If I go inside what can I look for to tell between a standard and a "posi"?
Old Jan 24, 2001 | 12:00 AM
a73camaro's Avatar
ebay has alot of pics, just to a search, plus there is tons of stuff on the web.
This is a posi carrier.
This is an open carrier
Old Jan 24, 2001 | 10:24 AM
greearhr's Avatar
Thanks a heap for the pics. Now I know.
92R/S, 305TBI, AUTO, grocery getter for now.
Mexinugget
Aug 3, 2014 10:47 AM
morace99
Jul 18, 2012 04:51 PM
Bman92rs
Sep 20, 2010 01:09 PM
MrMaro92
Fabrication
Apr 25, 2010 08:10 AM
Mechanix
May 7, 2004 12:20 PM
