700R4 Help Please
Car: 1991 Camaro RS
Engine: 350 SBC
700R4 Help Please
I took out the 3.1 FI V6 with 700R4 trans out of my 91 camaro RS and I am putting in SBC 350 4bolt main with a 700R4 out of a 1988 gmc/s-10 4x4. I notice the output shaft are different length when I pulled tail shaft cover of the one from camaro but the splines matches up with drive shaft. So what do I do? take them apart and switch the output shaft or what? I guess if I would have gotten newer trans I wouldnt have this problem but the price was right. Any info will be greatly appreciated Thanks
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Re: 700R4 Help Please
Yes. There are about 6 different output shafts in the 700R4's.
AWD (sy/ty)
4WD
Corvette
Std with short end splines
Std with long end splines
You should be able to reuse the one from the V6 tranny.
AWD (sy/ty)
4WD
Corvette
Car: 1991 Camaro RS
Engine: 350 SBC
Ok cool thanks for that info. Is there a certain way to remove the output shaft? do you have to remove the governor assembly to do it?
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
