For those with SLP Positraction
Old Feb 6, 2001 | 10:15 AM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Did you get the high performance unit or the OEM? Are you satisfied with the performance? If you got the OEM do you wish you had gotten the high performance one? Any help would be appreciated thanks, Tony
Old Feb 6, 2001 | 11:25 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
I have the HD Torsen differential and am very happy with it. It works great in the corners and I've pulled 1.96-second 60-foot times out of my small-cam 305.
Greg Westphal
'87 IROC 305TPI/A4
Old Feb 7, 2001 | 08:12 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
I've got the HD Torsen in my 92Z, and the take-off for my wife's 96 T/A w/RamAir.
I like the HD unit, have about 35-40k on it,and it has withstood both the pounding I gave it with the L98, and the pounding with the 383. It is smooth on the street for engaging & disengaging around turns. No surprises as I've had with other units.
I've put down 1.914-1.934's repeatedly with my SZ50's with no problems. I like it.
KevinP92Z
92 Z28 383 SLP cam,SLP headers,SLP 2ontheLeft,Trick Flow TW heads & pistons,Edelbrock base,Accel SuperRam,52mmTB,Scat Crank & forged ConnRods,MSD 6AL,SLP convertor,Baer 13/12" Track,Moser axles,Hotchkis,Genuine GM 3.42s,SLP HD Torsen,17x9" chrome SS rims
96T/A w/SLP Ram Air,SLP 2ontheLeft, Bilsteins, Baer, Hotchkis, Genuine GM, Torsen
76 4X4 Blazer 400TPI project
Old Feb 7, 2001 | 04:21 PM
kwikgta's Avatar
Had mine 1 1/2 years,absolutely one of the best things I have bought for my GTA!!!!!
92 GTA(only 226 made)ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
meeklay812
Oct 1, 2015 03:46 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
