sloppy shifts!!!!! help!!!
Old Feb 13, 2001 | 06:48 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have a little problem. I swapped out the 305 TPI i had and put in a minirammed 406. With the 305, there was crisp shifts at 4800 everytime at WOT. normal shift was about 3000-3500.
Now, the car shifts into 2nd and then 3rd at around 1800-2000. So I am constantly in 3rd gears. Any ideas?
It has a vigilante convertor with a 3000 stall. could the springs be out of whack?
thanks
Steve
Old Feb 14, 2001 | 06:42 PM
Nordbert's Avatar
Sounds like the TV cable is too loose.
Release TV cable lock and pull cable to rear of car. Reset cable lock. With engine off, push accelerator pedal to the floor. Cable
should ratchet to proper position. Take car
for test drive.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
greenyone
Sep 2, 2015 03:39 PM
