Where is the 9 bolt rear end fill plug?
Old Feb 20, 2001 | 05:24 PM
David Petersen's Avatar
OK I give. Where is the fill and check plug on the Borg 9 bolt rear end? Is it the black cap on the rear cover?
Old Feb 20, 2001 | 07:54 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
yep
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Feb 20, 2001 | 10:13 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
You found it. Carefully pry the rubber plug off with a putty knife or screwdriver. Then you may want to put a little silicone gasket sealer on it when you re-install it.
Old Feb 21, 2001 | 02:28 PM
Boooooyaaa! Thanx a lot for the help.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
