REAR END DRAIN PLUG STUCK?!?!?!
Old Feb 19, 2001 | 04:35 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Whomever put the plug back in last stripped the hell out of it. Tried with ratchet, it just stripped more. Tried with a reversed thred screw to back it out, and it still wouldn't budge. Is the plug it self a reversed thred? What can I do?! It's like a big hole now. HELP!
'85 z28 TPI 305 late model. Can't find numbers on the rear end, 120k original i think.
Old Feb 19, 2001 | 05:25 PM
The ODB's Avatar
It is not reversed thread.
relax, it is not a big deal.
you can warm the area up with a propane torch (not oxy/acet). If the plug still doesn't come out, then MIG a large bolt to the plug and force the plug out using the bolt to pull on.
Once the thing is out just retap the hole for the next larger size pipe-plug.
Remove cover and drain to clean out any debris from this operation.
There is no pressure in the rear-end (it should be vented) and the fluid level should stay below the plug, so little worry of leaks from the plug.
ODB
Old Feb 19, 2001 | 05:31 PM
Got her! Thanks!
Old Feb 23, 2001 | 01:33 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I would think it is easier just to replace the cover with another from a pick-a-part.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
