Expierence with junkyard flywheels
Old Feb 24, 2001 | 07:57 PM
84FTA's Avatar
Well, the time as finally come. My dad's clutch started to chatter in his jeep (after 40k miles of using the clutch like a brake at red lights, who'd of guessed???). What are your guy's expierences with junkyard flywheels? How much did you pick it up for? How did it turn out?
I have really "no" fear of junkyard flywheels except of the car had the flywheel turned then it was junked. I know you can see the obvious blue/brown/black spots (mine was all three colors!!) but I've often wondered what would happen if someone turned a blued flywheel then drove the car into the wreckers.
1984 WS6 Trans Am Hartop
Former L69 Car under restoration
1984 Trans Am T-tops
4-bolt main 350, performer intake, headers, Holley 650, T-5, hayes clutch, dual elec. fans and 3.23's.
Daily driver and restoration
13.98 @ 101
Old Feb 25, 2001 | 12:48 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They're about as good as any other used flywheels. I'd guess you have about a 3 in 4 chance of getting a good resurfaceable one; not the greatest odds, but not hopeless either. Maybe if you take what you get to an off-road place or something like that, that specializes in Jeep, they could tell you if the one you get is too thin before you spend the money and effort to find out the hard way. Or, just compare it ot what you've got, and if it's as thick or thicker, it's probably OK.
Chevy flywheels have a bevel around the outside edge, that is supposed to serve as the indicator for being worn out. If it has to be turned past the bevel then it's no good. Maybe Jeep has the same sort of thing, I'm not sure.
ICON Motorsports
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
