differance between trans
Old Nov 9, 2008 | 03:00 PM
EchoMirage's Avatar
Car: 87 IROC
Engine: 383
Axle/Gears: no idea
the douche i bought this car from gave a shytload of extra parts, 2 of which he claimed was a blown 700r4, and a good TH350. i come from LS1s and 2nd gens with T10s......this is my first try into 3rd gens. how do you tell the differance between the 2? theyre both out, laying on the floor. i know the 700r4 is longer, but havent measured them yet. one does have a plug for a 4 pin harness type connector, while the other doesnt.
Old Nov 10, 2008 | 10:14 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: differance between trans
the 4-pin plug is where you connect the wiring for the lockup torque converter. 700R-4. Also, the TH350 should have a vacuum modulator, or at least a hole for one, just above and to the passenger side of the mount.
The oilpan is another way. TH350 pan has a corner that's "cut" while 700R-4 pan is nearly perfectly square in comparison.
A 700R-4 has the same gear ratios as the 4L60E used behind the LS1s
Old Nov 10, 2008 | 03:43 PM
EchoMirage's Avatar
Car: 87 IROC
Engine: 383
Axle/Gears: no idea
very nice, good info. thanks. i do remember seeing a vacum canister on one trans. ill go out there soon and find out. the douche i bought the car from couldnt tell his *** from a hole in the ground, so i couldnt trust a word he said.
Jorlain
Aug 24, 2022 05:11 PM
Thomas
Exterior Parts for Sale
21
Oct 7, 2015 05:33 PM
Thomas
Oct 3, 2015 05:34 PM
Jlanz55
Aug 17, 2015 07:15 AM
