Difference between truck 700R4 and 3rd Gen 700rR4
Old Nov 12, 2008 | 12:06 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Besides the tail shaft being different are there any other differences like gear ratios and stuff like that?
Old Nov 13, 2008 | 01:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Difference between truck 700R4 and 3rd Gen 700rR4
Internal gear ratios are the same in every 700R4.
Old Nov 13, 2008 | 02:29 AM
MADMAXGTA's Avatar
Car: 89 TTA
Thers a few,Itll work but it might not feel the same.It would help if it was the same year, then the pump might have the same amount of viens,the more viens the better.and the servo might be diffenrt,vett 700r4s have a bigger servo then 3rd gens stock.
the spring that connects to the throttle/kick down cable could be a differnt tolerance making it difficult to adjust,and yes tailshafts,but if you have your old 700 you can swap these things yourself.
Old Nov 13, 2008 | 08:04 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Make sure its a 700r4 from a V8 and not V6. The bolt patterns are different.
Old Nov 13, 2008 | 11:42 AM
MADMAXGTA's Avatar
Car: 89 TTA
also make sure the speedo gear is the same color or your speedometer will be off.swap it with the old one.
Old Nov 13, 2008 | 03:43 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
TC dust cover bolt location changed.
Yeah I know, it's a biggie
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
