87 iroc with 3.73's, tranny gear question
Old Mar 7, 2001 | 11:35 AM
leirch's Avatar
Ok, I need to get this speedo working properly, not only so i know how fast i'm going, i don't want 1297462198421 miles on my odometer.
Would it be possible to get all of the gears for an 85 l69HO that came with 3.73 gears? What all would i need? driven/tranny gears?
Thanks,
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Mar 7, 2001 | 02:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Assuming you have an automatic, this info is in the FAQ on here.
15 tooth, and 45 tooth, for 3.73 gears.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 7, 2001 | 03:16 PM
leirch's Avatar
Nope, i have a T5, thanks for the Auto info. I found that info when doing a search. But the manual tranny info doesn't seem to be anywhere...
Old Mar 7, 2001 | 06:58 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Everyone says 7 and 21 for t5 and 3.73.. Go to www.hanlonmotorsports.com They have a calculator...Kevin
Old Mar 7, 2001 | 10:08 PM
leirch's Avatar
Kevin,
Thanks, i'll check it out!
hectre13
Dec 11, 2023 08:14 AM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 11, 2015 03:17 PM
