Richmond 6 speed... anyone know anything?
Old Feb 27, 2001 | 08:40 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Hey,
I am planning to swap a 350 into my car sooner or later and I want to have a 6 speed behind it.
What would take less fabrication/hassle to install? The GM T-56 (off of an earlier model f-body) or a Richmond?
What is involved in either swap....
Thanks!,
Daniel
http://kiztope.50megs.com
92 Rs 3.1/T-5
KYB Shocks and Struts, Blue Streak cap and rotor, neato new radiator!, RapidFire plugs
An overhead console!!
Clarion Head Unit,
Pioneer 6x9's,Cerwin Vega Plate 4x6's
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14(?))
"No one knows until they learn" Leon Calrinsky (99)
Old Feb 28, 2001 | 10:00 AM
ScreaminDeamin85Z's Avatar
i am in the process of getting all the parts that i need for my swap into the car for a t-56. from what ive read it looks as if the t-56 is easier to swap in becasue of all the aftermarket parts availiable , like the crossmembers/torque arms and other stuff. plus it cost less the buy to begin with.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 19 lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Mar 6, 2001 | 12:03 PM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
Thanks man
Old Mar 8, 2001 | 12:28 PM
327 firebird's Avatar
I have a richmond 6 speed and IMO I think its just a much better tranny and I'm very happy with it. I did go the hard route and bought the regular richmond which I had to get a tranny mount bracket made and a drive shaft 3 inches longer but that is because the engine I dropped in there already had a 10 spline cluth brand new and I wanted to save money. not needing to buy a new clutch and the 10 spine tanny is a few hundred dollars cheaper. However they do make a direct swap in richmond 6 speed for a 3rd gen firebird and corvettes. By the instuctions they said they are supposed to go right in. The only thing you will need is a yoke off a drive shaft from a Turbo 400. And maybe a new speedo driven gear, the richmond uses a 8 tooth drive gear as opposed to a GM 7 tooth. Other than that its easy and a much more strong tranny. Rated at 450 ft.lbs. of torque
Old Mar 8, 2001 | 03:57 PM
superz's Avatar
450 that is what the T-56 is rated at. so the richmond is not stronger!?
9192camaro
16
Feb 3, 2019 12:21 AM
83 Crossfire TA
Sep 18, 2015 12:01 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
89fast5oh
Aug 20, 2015 08:34 AM
bad camaro RS
Aftermarket Product Review
Mar 24, 2001 07:10 PM
