Need help on building a rear end to hold 450 rwhp
Old Nov 14, 2008 | 10:04 AM
gadocbar's Avatar
Car: 86 Z-28
Engine: 350 VORTEC
Axle/Gears: STOCK
i have a 86 z-28 with 350 built and procharged with a tremec tko 5 speed and a broke down 10 bolt 7.5. will a built 10 bolt 8.5 hold that power and if so will the wheels stick out far from the car
Old Nov 14, 2008 | 12:25 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: Need help on building a rear end to hold 450 rwhp
it all depends. Every tranny is different. I have seen some people with there stock 10 bolts run 11's. A 8.5 should be fine though for awhile
Old Nov 14, 2008 | 12:33 PM
Shagwell's Avatar
Car: projects.......
For the cost of getting a 8.5" 10-bolt under the car, plus the cost of building it up to take decent power, it's not likely to be worth it. You'll have almost, if not as much, into doing so as just swapping to a bolt-in 12-bolt. Obviously, a mild 12-bolt will handle that and then some if you want to build it up.
Old Nov 14, 2008 | 02:12 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
an 8.5 is not a bolt-in. It's a custom, one-off conversion.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
