Which flywheel
Old Mar 11, 2001 | 08:39 PM
Sinful One Z28's Avatar
Which flywheel
Hey there all...
I know this is a bit off the beaten path, but I wanted to give it a shot. I'm building a 383 stroker motor for my 79 Z28. It's currently has a TH350 in it. In the stroker motor kit I'm getting, they are sending me the kit balanced with a harmonic balancer and auto flexplate. To my understanding this kit is EXTERNALLY balanced like a small block 400.
Now, I want to change my TH350 to a 4 speed (going into the 79 Z28). What flywheel do I get? Will I need to get a special flywheel for it? or would I have to have the whole kit balanced again?!
I'm trying to get all this info prior to me ordering the kit. I was hoping to put in the original Z28 11" flywheel & clutch assy (new, of course), but I know none of these cars came with a SB 400, so I don't know what flywheel to use.
Someone please help me if possible. I'm going to call the people selling the kit (Powerhouse in CA), but I don't want to have to buy a brand new flywheel from them if I don't have to.
Thanks all and cya on the streets...
Sinful One Z28
(Formerly: Sinful One RS)
79 Camaro Z28, just acquired, stock 350, 3.42 rear, TH350, no 1/4 mile numbers yet...
91 Camaro RS w/305 TBI
3.23 Rear End w/disc brakes
145 speedo
Z-28 fog lights & grille
Pathetic 16.32 in the 1/4
Sinful One's Domain
Old Mar 11, 2001 | 09:27 PM
ScreaminDeamin85Z's Avatar
call centerforce, Mcloed, or hays. they will know which one EXACTLY that you need.
centerforce;
18009325882
Mcloed
7146303668
Hays
2166888300 ext: 500
i would call centerforce first because its free and they seemed to be nicer thatn the others! at least thats how i felt it.
Brandon
"ScreaminDeamin 360"
350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
New project-89 IROC
Soon- 6 speed, Pro 5.0 shifter and 4.10's
http://users.argolink.net/bvana
http://ScreaminDeamin.cz28.com
Old Mar 11, 2001 | 09:28 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The 454 flywheel is identical to the 400. So you could lok for a junk one of those.
Centerforce and most of the other people like that can supply the flywheel you need.
You could also take a regular 168-tooth flywheel to a balancing shop and have it "unbalanced" to the stock 400 spec.
There are many ways to get the right thing. In my 83, I had a regular 305 HO flywheel (the light one) "unbalanced" to match my 400, and the whole deal balanced as an assembly.
ICON Motorsports
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
