drum to disc rear
Old Mar 11, 2001 | 05:16 PM
mirage2991's Avatar
drum to disc rear
any of ya did the switch? I just did it on my car but the breaks are kinda weak...what need to be changed? master cylinder? prop vlave? both?
ps: car is 85 Z28, rear is out of an 84 TA
Old Mar 12, 2001 | 01:32 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you bleed the brakes after you did the swap?
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 12, 2001 | 05:43 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You forgot to replace the prop valve. Check this link out: 10 bolt swap
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Mar 12, 2001 | 12:01 PM
mirage2991's Avatar
thanks for the info guys...I figured that I needed the prop valve (which I have) but I also find out the master cylinder has a diff part number too...so do I need to change it??
Old Mar 13, 2001 | 12:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, the m/c was different between J50 (disc/drum) and J65 (4-wheel-disc) cars. The piston's larger inside the J65 master cylinder.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Mar 13, 2001 | 06:13 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
......your axles won't fit inside the rotors without machine work.
Unless you get axles off the disc brake car.
'88 Camaro RS 2.8L
'88 Formula 350 (Too many mods to list...)
Old Mar 13, 2001 | 07:35 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
New master cylinder? My brakes work great, no problems from what I can "feel" with just the J65 prop valve and old J50 M/C. Maybe I have yet to feel peak performance?
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
'97 Bonneville SSE
Orr89RocZ
Apr 25, 2016 08:28 AM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
