Gear Ratios?
Gear Ratios?
I own an 84TA 4bbl HO. Unfortunately it is only a regular differential
and I'm looking to switch in a posi unit. I was wondering what the gear ratio would be of this REGULAR differential, and if it is available in a posi set up (that way I don't have to worry about changing the speedo gear). On the Tech page, it was listed that my kind of 84 (AUTOMATIC) would have either 3.42 or an optional 3.73. Thanks for any replies.
and I'm looking to switch in a posi unit. I was wondering what the gear ratio would be of this REGULAR differential, and if it is available in a posi set up (that way I don't have to worry about changing the speedo gear). On the Tech page, it was listed that my kind of 84 (AUTOMATIC) would have either 3.42 or an optional 3.73. Thanks for any replies. Joined: Jul 1999
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Do you have a set of 3 letter codes on a sticker in the glove box? What are the ones that start with G?
Or, what are your RPMs on the freeway at 70 MPH in drive (not overdrive)
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
The sticker in the counsel is destroyed. I can't read it. I'll have to check the RPMs. I was just wondering if anyone might know off hand. If not... I'll have to use the equasion. Thanks.
Well, you looked it up and it said you can have 3.42's or 3.73's. If you dont know which one, how are we supposed to know?
You could have either.
You could have either. Joined: Mar 2000
Transmission: 4L80E/4L80E
Put in a PowerTrax and you'll have power to both wheels, and you'll keep whatever gear ratio you have now. It's about the same price as a posi carrier, and since you can do it yourself, you won't have to pay somebody to set it up.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/LB9 block, ZZ3 cam and intake, TBD heads, Hooker headers & y-pipe, 3" Catco cat).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
