disc brake rear swap question
I'm swapping a disc brake rear into a thirdgen that originally had drums. Do I have to change the master cylinder and proportioning valve?
'88 IROC TPI 355, fully balanced, 9.75:1 compression, fully ported '70 truck heads(for now), Harland Sharp Roller Rockers, Comp Cams TPI cam, fully ported '90 speed density TPI with '86 base so it fits older style heads, Crane AFPR, Flowmaster 3in. exhaust, Edelbrock TES headers, all emissions equipment is still intact, plan on burning my own chips, many more mods and parts on the way as time and money permits =(
Best E.T. with TBI 305: 16.11 @ 82mph
Haven't been to track with new motor
Won bracket races at Numidia Raceway with my '70 Nova
In memory of Dale Earnhardt, I'll miss cheering for that black #3 on raceday!!!
Car: 1986 Firebird
Engine: 2.8 V6
Depends on the years. I assume your 88 Iroc has the drums. What year is the disc brake rear from?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Car: '92 RS
Engine: In pieces
Transmission: Built 4L60
Theoreticly, yes you should change them. There is this little thing called "Brake Balance" that the big three make the brake suppliers work on a lot, big reports, lotsa testing and more reports. When you put rear discs on the back you throw this way off. Will you notice the differnce? Probably not. You will probably never push your car to the point where You will notice. It's mostly on Very low Mu surfaces and sometimes hard braking on spilt Mu.
To answer you question: Should you change the Proportioning valve and M/C?? YES
Do you HAVE to? NO
But if you do change the M/C and P.V. you should also change you Booster. I guarentee the Boost rate for a Disc/Drum is different from a Disc/disc setup.
Just my .02
-Lars
Do you HAVE to? NO
Just my .02
-Lars
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
