quick question
Old Dec 2, 2008 | 04:17 PM
flying89's Avatar
Car: 1989 Camaro RS Drag Car
Engine: SBC 388 Stroker 93 pump gas
Transmission: Built turbo 350 3500 tci converter
Axle/Gears: Stock axles 4.10 gears
quick question
ok so im taking the brace from the rear end off. the one from tranny to rear end. the bolt on top hits the floor how do i go about getting it put witout a torch dont have one avaible.
Old Dec 2, 2008 | 04:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: quick question
unbolt the arm form the rear, then slide it out of the trans mount.
There are 4 bolts holding the tailshaft of the trans on, remove them once the arm is out, and you can remove the tailshaft and take the bolts out. You obviously have to remove the driveshaft to do this.
You may loose some trans fluid when you do this, be sure to replace it.
Old Dec 2, 2008 | 05:45 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: quick question
Torque arm? Which bolt on his which end? Please reread your posts.
JamesC
Old Dec 2, 2008 | 07:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: quick question
hmmmmm, read it as he was taking the mount off the trans, but if you are looking to remove the bolts form diff side, put the car on jackstands and lower the rear as far as you can, watch out for the brake line! With the rear dropped you will be able to remove the bolts.
Old Dec 2, 2008 | 11:29 PM
ed o's Avatar
Car: 64chevelle/smokey trans am
Engine: 350 p600 pro charger/350
Transmission: 350/700r4
Axle/Gears: 3.36
Re: quick question
there should be a small bolt that will release the arm from the trans. Just pull the small bolt and the bracket will release and the arm will hit the floor pan. No need to pull the long bolts out of the housing (not the ones that hold the extension housing to the trans-those are short.) unless you are replacing the arm mount. In which case you'll need to do what 86TA suggested.
If someone put the long bolt in the opposite way-I see your dilema!! Next time install the long bolt the opposite way so that the nut will come off and it won't be an issue. That is the way I do it during installs to make it easier on the next victim.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
