Torque converter bolts: How much do you tighten?
Hi, I just added a 3000 stall to my 62-67 327 engine. I was wondering how much I torque down the torque converter to flywheel bolts, or any tips on putting them on. thank you!!
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
2.02/1.60 valves
th-350 tranny
489 lift cam
7 quart oil pan
Keith Black pistons
Car: 4
Engine: 6
Transmission: 5
They're about 3/8" or 10mm IIRC... that would be in the 35 ft-lb range
ICON Motorsports
ICON Motorsports
Car: 1986 Firebird
Engine: 2.8 V6
I used blue Loctite on my torque convertor bolts...
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Bolts on all the fbodies I've worked on are exactly 15 MM. 35 is what I torque em to also.
92 Z28 5.7
Trick Flow 23° heads, Comp Cams XR270HR-10 cam, Accel intake base + ported TPI,
TES headers, Flowmaster catback, MSD ignition, #24 SVO injectors, 1LE aluminum driveshaft.
Click here to see pics of my car.
Check out our car club Truspeed
Check out the Bin Archive for all your .bin needs
92 Z28 5.7
Ragtop Man
Sep 12, 2015 12:23 AM
