Torque Arm
Old Mar 22, 2001 | 03:42 AM
knightfire's Avatar
Car: 1984 Trans Am
Transmission: Manual
Torque Arm
Hi all,
I just replaced my T-5 tranny last night in my bird. A 4-speed manual from a newer T/A now resides underneith. I knew the T-5 was longer than the 4-speed, but I thought it was ok since I had a longer driveshaft off an automaic and it fit just fine. Seems I forgot about the torque arm. The 4-speed dident have the torque arm bracket on it, the T-5 torque arm bracket wont fit, and even if it did it would be to short to reach the torque arm itself. So my questions to the group are now:
1. Would a torque arm bracket from a 4 speed work correctly... more percisely are all the torque arms on these cars the same length? or are there diffrent sizes depending on wich tranny the car has?
2. Would a torque arm bracket off an automatic fit the 4-speed? (incase I have to go pull it off in a junk yard)
3. As a very last option would it be wise to connect the torque arm to the underside of the transmission "hump" (car body) by using spacers and bolts?
4. Does anyone live near Nebraska and want a T-5 tranny / bellhousing for free? It shifts ok in all gears but when you go "racing" it's easy to miss 3rd gear and over rev. I just dont like the internal shifter of the T-5 or the feel of it, and this is why it got replaced.
Many Thanks in advance,
Andrew
1983 Firebird
327 bored .030
4-speed manual
Edelbrock 600cfm carb.
Edelbrock Performer intake / cam.
Pete Jackson gear drive.
MSD 6a ignition
yackety, smackety, blah, blah.
Old Mar 22, 2001 | 05:39 AM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
E-mail Steve Spohn...
His torque arms are awesome and are well worth the price you pay.
His torque arm also bolt up to the transmission crossmember, which would cure your problem.....
Sportsman II 72 CC heads, Pete Jackson gear drive, Performance Resources chip, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go stage 3 shift kit, Vigilante 9.5" 2800 stall convertor, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
raven
Old Mar 22, 2001 | 07:46 PM
RARE-ROC-Z's Avatar
where do you live in nebraska? i would take it if you dont want it.. why turn down something free. and i am looking for something to replace the one in my S10 or to just fool around with and rebuild.. thanks man. and my email is JayC003@hotmail.com. so email me with your info. thanks jarrad.
ps email me soon because i am on spring break next week!!
Jarrad
1990 IROC-Z L98 350 TPI
TH-700R4
G92- 7.5" 10 Bolt 3.23gears
Bright Red Hardtop/ Grey Custom Interior
5,507 IROC's Hardtops/Ttops; 2,415 5.7L IROC's Produced in 1990
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
Old Mar 24, 2001 | 04:26 AM
knightfire's Avatar
Car: 1984 Trans Am
I really dont want to replace the whole Torque arm, Just want to get it mounted correctly and safely.
Andrew
1983 Firebird
327 bored .030
4-speed manual
MSD 6a ignition
Old Mar 24, 2001 | 07:59 AM
82camaro's Avatar
Car: 82 camaro SC
"A 4-speed manual from a newer T/A now resides underneith"
What newer T/A came with a 4sp manual? 82 is the only year for a 4 speed manual in a third-gen. A custom bracket hooked to the floor pan might work OK. I would try a custom bracket that hooks to the crossmember if you don't want a spohn torque arm.
Which model of 4 speed is it?
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Old Mar 25, 2001 | 03:21 AM
knightfire's Avatar
Car: 1984 Trans Am
Hey, thanks for the help. Actually when I got my parts car years ago, this 4-speed was an additional bonus. The guy asked me if I wanted it so he could clear out his garage. He went on to say that the tranny was out of a newer T/A, the parts car was an automatic.
I identified the tranny as a T-10 ? Borg Warner 83mm. It has two shift levers on the side, and the reverse lever is on the tailshaft portion. Everything bolts up correctly, and there is 3 mounting points for the Torque Arm bracket. Anyone have a torque arm bracket for a four speed that they'd want to sell?
Thanks 4 your help,
Andrew
1983 Firebird
327 bored .030
4-speed manual
MSD 6a ignition
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
