Attn: Pro-Built Automatics
Old Apr 1, 2001 | 06:14 PM
Marc 85Z28's Avatar
My 700r4 needs a rebuild. I'm curious as to what my best option would be. Buying a total rebuilt unit from someone for $1200+ or rebuilding my current trans. I will need it to be capable of at least 450HP and will want a 2200-2500 stall TC as well. Would I be better off buying one of your rebuild kits and a TC or buying a whole new trans considering I currently have an 85? Also, what would you consider to be a good price for a rebuild?
1985 Z28, Jasper Class 1 350, Edelbrock Performer intake, Dual snorkel air cleaner, K&N, Edelbrock headers, Catco 3" cat, Hooker 3" cat-back, Richmond 3.73's, Transgo shift kit, JET Stage 2 chip, Hypertech coil, Lakewood LCA's, Powertrax locker, SSM subframes, Centerline Auto Drag's
Old Apr 1, 2001 | 08:33 PM
Wayquick4u's Avatar
try out www.thetrannydoctor.com When i bought their 700r4 it was $800, now its $900. I make about 600 horsepower and have had no problems with it whatsoever. Great 1 yr unconditional warrenty on it as well.
Old Apr 1, 2001 | 08:38 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I just installed a "Raptor" kit in a friends car, and I have mixed feelings about it. They screwed us on the sprag, VB gaskets, gave us inferior seals, luckily for me, I had spare parts to make it all work, but I won't go there. These kits are not designed for the DIYer. If you have no clue, call one of the "builders" and tell them what you want, and let them build it for you.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 1, 2001 | 10:11 PM
Pro Built Automatics's Avatar
The rebuild kits I carry use only top material such as Borg Warner clutches, bands & sprags, Alto steels, Sealed Power filters, National front & rear seals, Clevite & Dupont (teflon) bushings, Transtec paper & rubber kits, American made sealing rings,& Trans-Go Shift & Performance Shift kits, GM intermediate/reverse boost valve. I even include a new stator support. For torque converters I use & distribute Continental (non-lockups), Precision Industries Vigilante (lockups). If I left something out I apologize. If you are looking at doing it yourself, then I would have someone who is very familar with this transmission help you out so as to avoid unnesessary problems . To build you a custom built transmission I need to know the particulars on your vehicle, rear end gear ratio, what has been done to the motor, type of driving you do, etc. Please give me a call 800 7763288 Mon-Sat 10-6 PST, or if you get this message before midnight on Sunday give me a call and I will answer any questions you might have. I give a one year warranty on both the transmission & torque converters.
Hope this helps!
Lbibb
May 5, 2016 12:00 AM
jrdturbo
Mar 31, 2016 02:58 PM
1992Z28!
Nov 19, 2015 07:33 AM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
