Backlash?
Old Apr 3, 2001 | 10:55 PM
wolfie's Avatar
Backlash?
The pinion depth was no problem. I've switched carriers and need an algorithm (list of steps) ((detailed please)) for checking backlash. I know the spec is .008 of an inch but have no idea how to check this, what to check it with, and what it actually measures. I would be greatly honored to be enlightened.
Old Apr 4, 2001 | 12:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You measure it at the outer edge of the ring gear teeth. It's how far the ring gear moves back and forth with the pinion held still. A dial indicator is the correct tool.
ICON Motorsports
Old Apr 4, 2001 | 06:21 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Exactly what RB said. Here is a link that shows a rear being put together, including backlash: 10 bolt
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 4, 2001 | 09:05 PM
OLDYELLR's Avatar
Car: '85 IROC
You *do* need a dial indicator to measure backlash. Maybe someone with a lot of experience could guess at the backlash, but even just .005 feels like more when you rock the ring gear back and forth, so it's easy to end up with too little by just guessing. Moving .004 of shim will change the backlash .002, according to Helm.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
Old Apr 5, 2001 | 07:33 PM
wolfie's Avatar
Thank you all for the info. I understand why the backlash is important but still need to know what kind of indicator, where to get one, and where to mount it to check the spec. The link was great, by the way, and I printed the instructions for reference. However, my ignorance still requires a more specific instruction sequence. Thanks again to all for what you have provided.
gord327
Oct 3, 2015 01:25 PM
dimented24x7
Sep 17, 2015 06:58 AM
camarokev400
Jun 30, 2005 10:29 AM
25THRSS
Feb 6, 2004 05:27 AM
alloy
Nov 27, 2002 01:33 PM
