83 700r4
Old Apr 5, 2001 | 06:39 PM
85rez_runner_TA's Avatar
83 700r4
I had a 83 z28 camaro with over drive auto. When it shifted into second at wide open thorttle it would chirp the back tires. Now I have a 85 T/A and this one wont do it. What was in the transmission of my 83 that caused it shift like that? I was told there was no shift kit in it either.
Old Apr 5, 2001 | 06:47 PM
leirch's Avatar
Well, are you sure this 85 is the problem? Maybe the 83 didn't have any tread? or maybe the engine was slightly more modified? There are so many different variables to contend with.
Brendan
1987 IROC-Z L98,SuperRam,EB 6085's,LPE 219/219 Roller, Crane 1.6RR, EB TPI Base, 58mm TB, ADS 24#, AFPR, K&N, EB TES, Catco Cat, 3" Borla Cat-Back, Accel cap,rotor,distro/other crap, MSD 6AL, MSD Blaster 3, Aluminum DS, 94 Disk Rear, Adjustable Valve, Precision 3.73 Gears, Sub-Frame Connectors, Hotchkis Lower Control Arms, KYB Shocks/Struts, Suspension Techniques Lowering Springs, Polyurethan Bushings all over the place, Moog Upper/Lower Ball joints and Tie Rods ends/Idler Arm,
To see the ROC, Check out the webpage Here
Old Apr 6, 2001 | 12:31 PM
The camaro had brand new tires on back, engine was stock. I talk to somebody else with a 83 trans am and they said there's would do the same.
Old Apr 6, 2001 | 01:27 PM
leirch's Avatar
How many miles are on this 85 car?
How many on the other car?
Which motors were/are in each?
Old Apr 6, 2001 | 05:34 PM
the Camaro has 93000 on it and the trans am has 63000 miles on it. They both have the regular 305, with carburators
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
