pilot bearing for t56
Old Apr 9, 2001 | 07:51 AM
bhagg's Avatar
I am installing an OEM t56 behind an old style (two piece rear main) engine. Do I need to get a special pilot bearing to work with the t56, or can I just use the same type of pilot bearing that goes in the back of the two-piece seal crankshaft? Do all Chevy v8s use the same pilot bearing all the way through fourth gen applications? I already have the special flywheel that this combo requires. Thanks - Bill
Old Apr 9, 2001 | 08:25 AM
3RDGENFRANK's Avatar
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I'm pretty sure they are all the same. I used a regular bronze pilot bushing that you can get at any auto parts store for less than $5.
1992 Camaro Z28; Engine:383 w/Ported Edelbrock RPM heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, Comp Cams 1.5 Roller rockers and lifters, Comp Cams Triple Valvesprings, SVO 30 lb injectors. Holley/Walbro 255 lph in-tank pump, Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, SLP Clutch, Pro-5.0 Shifter, 4.10 Gear, Auburn Offroad Pro Posi. Super Ram. 17" X 9.5" Ronal FireHawk Rims w/ 275 40ZR17 Bridgestone RE 730's up front and Nitto Drag NT 555R's out back.
Double-Pump This! EFI Rules!
Old Apr 9, 2001 | 09:27 AM
Mark W. Winning's Avatar
I just went through this Saturday. I have a 97 six speed behind a 87 block. The pilot bearings are the same part number. If you want to make sure, go to your parts store and check, say a 85 Z-28 with a t-5 and compare it to a Z from the year of you T-56.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
