difference in weight between 700r4 and t56
Subscribe
Mar 10, 2001 | 10:22 AM
Does anyone konw the weights of these two trannies?
355 10:1 , AFR 190 heads, LT4 HOT cam w/ 1.6 roller rockers, complete Superram intake, 58mm BBK TB, 24# injectors, screens out of MAF, MAT relocated, March underdrive pulleys, Streetdampner, Crane HI-6 ignition, 160 thermostat, K&Ns, TES headers(Jet hot coated), Mufflex 4' cat back, B&M shift Kit, 2500 converter, and 3.27s.
Reply 0
Mar 10, 2001 | 10:28 AM
700R4 = 135 lbs dry (depends on case)
the 4X4 case is slightly heavier.
the stock torque converter is approx 45 lbs drained.
Reply 0
Mar 10, 2001 | 11:40 AM
What about the T56?
And I would like to know the total weight of the 700r4 complete with fluid and all.
I want to know how much wieght is saved with a manual vs auto
Reply 0
Mar 10, 2001 | 04:12 PM
I've never had a T56 on the scales but I don't think it saves any weight.
Reply 0
Apr 15, 2001 | 03:14 PM
Sorry to bring up an old topic but I did a search for the T-56 weight and someone said it is 125-133 lbs. Is the 700R4 going to be about 170 lbs complete or is it more than that? I'm hoping to make my car lighter with the swap too.
'89 Formula 383 TPI
Reply 0
Apr 15, 2001 | 09:37 PM
I am not sure on the t56 but, on the t-5 some one got the weight of every thing (fly wheel, pressure plate, pedals so on) and compared it to the 700-r4 and they came out very close to the same weight.
Reply 0
Apr 16, 2001 | 09:44 AM
T56 is 122 lbs empty.
I'm not sure I buy that the torque converter is 45 lbs empty.
Reply 0
Subscribe
