#10 Copper Ball under TV Cable bracket question?
Old Apr 17, 2001 | 08:13 AM
fast89's Avatar
The TransGo kit does not mention whether or not this copper ball needs to be put back in or not. Does it need to be there? The copper ball is at the top of the valve body under the TV cable bracket. No mention in Transgo kit but I noticed it needed to be there from GM manual.
1989 Pontiac Formula L98 Ported Plenum, Edelbrock 6085 Heads, Edelbrock HI-FLO Intake, BBK 52MM TB, Edelbrock TES, FlowMaster 3" Exhaust, Dual Cats, 3.27 Gear, CompuCam 2032 Cam, 1.5 Rollers, Ed Wright FastChip, Accel Super Coil, MSD 8mm Wires
Old Apr 17, 2001 | 12:40 PM
fast89's Avatar
Can anyone help me with this question?
Old Apr 17, 2001 | 07:24 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Many places tell you to omit it, but I'm a "by the book" person, so I always put it back. I think if you knew what it was for, you would put it back in.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Apr 18, 2001 | 03:12 PM
need4speed's Avatar
You can leave it in or out.
What does that ball do??
Well, it is a sfety device in case your tv cable breaks. It will force the line pressure
high all the time giving you wot shifts (even at part throttle.)
If you work on your own stuff you can leave it out. I have had some of them give me problems with the ball not un-seating with a cable that stretched. But I prefer to leave them in.
The only problem you will have by leaving it out is you will burn up the tranny if you forget to hook up the tv cable and keep driving it. As is you won't notice the early/soft shifts.
Frozer!!!
Jan 19, 2024 04:55 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
