NON COMPUTER 700r4
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
NON COMPUTER 700r4
What do i need to take the computer off the tranny and make it run fine.I posted before about the TCI Torque converter lockup kit from from jegs that locks up 4th gear.is there anything else i will need to switch it to non computer controlled tranny.I really want to keep a 4th gear or i would have switched to a th 350.
Thanks for your help...........
Car: 82 camaro SC
The 700r4 doesn't have a computer. Even the main computer doesn't 'control' the tranny. All it does is lock and unlock the torque convertor. The tci kit will take car of that.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
I was told also that 1,2,3 gear had to lock up also and that the TCI converter lock up only works on the 4 gear and that ill burn out the tranny by using the other gears.Is this true..
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
First gear will NEVER lock up, second SHOULD NOT be locked up, third MAY be locked up, and fourth MUST be locked up.
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
thats interesting way of putting it. mine (when i had it) would lock up according to how much strain i put on it, if i held it in second and let it cruise lightly it would lock up. in third gear it would lock up also if i was light on it, and same with forth. if i stepped into it tho, it would seem like it downshifted, when in fact it UNLOCKED the torque converter to get higher rpms quicker. all it does it bring down the rpms, cool the converter, and save some gas. and add a little speed if your doing 120 MPH in overdrive and wana get more top end :-)
Car: 1983 Z28
Engine: 6.6L 406
think about the B&M kit it costs more but it lets you control when the converter locks up (which MPH) It also has an indicator light on it so you can see when it engages so you can adjust it accordingly.
I WOULD RATHER PUSH A CAMARO THAN DRIVE AN IMPORT
1983Z28 350w/ edelbrock performer RPM power package with 64cc aluminum heads, dynomax shorty headers, 700R-4 with shift kit, 750cfm carb, edelbrock 3" exhaust system, ASCD SS hood, 16" IROC rims.
future mods:
completely done over suspension, black paint with flames, Hurst shifter, dakota digital gauge package, procharger supercharger.
future mods:
rs_z28_vert
Sep 30, 2015 09:47 PM
Damon
Sep 26, 2015 04:29 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
700, 700r4, car, computer, computerized, controled, controler, converter, lockup, make, noncomputer, r4, switch, trans, transmission
