T5 flywheel?
Old Jan 16, 2009 | 10:55 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
T5 flywheel?
i want to get a light FW for my 91 z28 305 with the t5 trans. its all stock. what is the stock weight? and if i could get some opinions what weight could i go down to? please help me out
Old Jan 16, 2009 | 11:10 PM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
Re: T5 flywheel?
hit up your local GM dealer... i got my light weigh GM flywheel for my two piece RMS 350 for like $220
Old Jan 17, 2009 | 06:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: T5 flywheel?
Welcome to TGO. Editing your profile to include make, model, engine, trans, etc. is helpful. It may be possible that you're already running the light-weight version (16 pounds vs. around 25 or so), depending on what engine your car is equipped with. IIRC, the light weight FW was found on TPI cars, L69's, etc.
JamesC
Old Jan 18, 2009 | 02:12 PM
benin360's Avatar
Car: 91 z28
Engine: 305 tpi
Transmission: t5
Axle/Gears: stock
Re: T5 flywheel?
JamesC
its a 1991 camaro z28 305 TPI with the T5 trans. all stock
Old Jan 19, 2009 | 12:43 PM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Re: T5 flywheel?
Zoom makes a complete kit, Lightweight flywheel,pressure plate,clutch disk,throwout bearing and pilot bearing for under $300... The pic shows a pilot bushing but the kit comes with a pilot BEARING...http://store.summitracing.com/partde...5&autoview=sku
Old Jan 20, 2009 | 05:19 AM
Pat Hall's Avatar
Re: T5 flywheel?
I'm not 100% certain, but I'm about 99% sure all the TPI/Z28 cars got the lightweight flywheel. Just about every time I've ever seen the standard weight flywheel, it's out of a RS with the T5. At least that's been my experience with the 87-newer, 1 piece RMS motors. You can easily tell the difference when you look at them. The heavier flywheel is a perfect, flat surface all the way to the ring gear, the lightweight one has recessed, unmachined casting past where the pressure plate bolt holes are.
Old Jan 20, 2009 | 06:12 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
Re: T5 flywheel?
Be careful with changing to a lightweight aftermarket wheel-my 88 GTA had that done by the previous owner and now the clutch fork sets too far back away from the slave cylinder, so the pedal only goes halfway before the slave cylinder is maxed out, and it will blow if you try and force the pedal down any more.
An adjustable clutch fork pivot ball may help with this, but my car also has that and it doesn't help, I think it's set to the stock setting.
Personally, when it's time for a new clutch, I'm going to replace the lightweight pressure plate in there now with a factory heavy one.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
