transmission
Old Apr 28, 2001 | 06:05 PM
rita's Avatar
transmission
I took out the transmission in my '84 Z28 Camaro. I need to know how to take the top part of the transmission off so I can see the gears. I took all the bolts off the plate on top and still can not get it off.
Old May 1, 2001 | 11:16 AM
PonchoTA's Avatar
You can't get it off because there is a shift lever rod attached to the shifter forks in the main case that runs all the way thru the tail housing to the shifter hole.
See my reply to "T-5 5th gear problem" on how to disassemble most of that part of the trans. After the tail housing is off, the top plate comes off by pushing it towards the pass. side and lifting up (almost simultaneously!)
Hope this helps,
Paul
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
